jerseyjim
Apr 25, 2014Explorer
Years ago I had the front seal replaced....(leaking tranny fluid) and while there, the shop told me it was most likely caused by overheating...even tho, they said, mine has the latest mods from the factory to avoid overheating. Gasket kit: $38. Labor $800. While working, I told them to put in a tranny temp gauge. So far, that gauge almost never goes over 160 degrees. So...overheating was not the problem. More likely a pinched gasket at assembly.
How heavy is your toad? And your V-10, like mine has a thermostaticly controlled fan...and it ROARS when engaged. Don't let that concern you.
An extra cooler can't hurt...but you must be careful: too MUCH cooling is not good.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
