svt440's avatar
svt440
Short Bed Ext. Cab vs Long Bed Four Door
Hey everyone. I have a 30' fifth wheel that weighs in around 8400lbs dry. Currently towing it with a 2003 2500HD Silverado Duramax. Truck is an extended cab, short bed (the shortest truck you can get aside from a two door short bed). I felt it get a little squirmy a few times at 65mph that made me nervous enough to back off the gas. Did it a couple times in a couple of hours. One thought I've had, is buying a newer four door, long bed, 3500 srw. My thoughts are, with the longer wheel base and the heavier suspension, I will be over trucked (at least for an 8500-9000lb setup) and not feel like I'm the minor like I do in my current truck. I know a dually would most likely eliminate that possibility all together (I see these things with the hammer down running 70+mph on the freeway with tri-axle fifth wheels!) but I'm really preferring a srw and given the fact that I have a lighter fifth wheel, I feel like a 3500 srw should be more than enough truck.
Question is, will I notice much difference between the combination of a greater wheel base, and the heavier suspension, or will it not change much? I know the HD series trucks are similar to a 1 ton, (or so I read), so I'm wondering if my only gain in this situation will be the longer wheel base. Any thoughts or experience? <- preferred! Thanks guys!
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
