H20ENG's avatar
H20ENG
Slide Questions
New to slides here. I want to make sure my slide is operating correctly and keep it adjusted properly. I have the Norco manuals but never heard about proper operation or adjusting for slide room orientation.
-What is the proper orientation of the slide while In/Out/ In motion?
When retracting, it makes sense that the top should touch first to ensure the seal is compressed and water tight. If this is correct, what is the proper clearance at the bottom flange when the top is touching?
-How about extending? I assume the roof should be sloped downward when the trailer is level for runoff? I will be installing a slide topper but still want to know.
-How tight should I be pulling the slide in? I want it to be water tight but don't want to stress or break anything. I cannot believe there are no limit switches on the motors. Seems all too easy to break something or get hurt if a cable lets go. I usually bring it in until the motor barely starts to labor and release the switch.
- I have read on this forum that slides should not be loaded unless fully extended. Is the floor of the slide not supported inside the trailer?
-I assumed there were rollers on the trailer floor and mating tracks or bearing surfaces of some sort on the slide. Now I'm reading about a "wear bar". Does the entire Darco undercoat of the slide ride on this bar? (and WTH, really!?) It seems it would just shred it over time. I cant believe that would be the bearing surface. Need lubrication?
-Baby powder vs PTFE for the seals? Both seem to have good reviews. Pros/Cons of each?
I'm sure I'll have more questions as I go along, just want to do it right and make it last.
Thanks All!
  • To clarify a bit- this is a new to us 2013 Premier 22RBPR with 1 cable driven dinette slide. It works fine, I just notice that it is pulling the top in slightly before the bottom. Wondering if this is by design, or is something I need to adjust. Cables are a bit looser than the 1/2" slack given in the Accuslide service manual. I will not do anything before fully understanding the procedure and desired end result.
    Thanks guys
  • If your camper is new you have no reason to mess, adjust, or attempt to change anything on the slides. They "should" be working properly. Make sure they work properly when you have your pre-delivery walk-through inspection with the dealer. He'll also explain how the slides work.
    If you are getting a used camper and the slides are not working properly.... well.... just run! and save yourself the headache. You won't miss anything.
    I've had my Outback for 5 years and have never....never.....never had to touch anything to adjust them. I figure if I try to tweek anything on them, I'll probably screw them up so bad, they'll be beyond repair and probably never work correct again.
    If it ain't broke ... don't fix it!
    Some slides can be walked on while retracted. Evidently according to these forums, some slides cannot. But if your slides have the refrigerator, cabinets, and stove built in them, you won't be walking on them retracted anyway.
    Slides work just fine .... ONLY when you don't mess them.
    If something is broken, then you've got another issue.
  • As far as how far out and in and/or how tight, when the mechanism starts that "click, click, click" you release the button.
    Since the drive mechanism is on the bottom of the slide the bottom of the slide will start the outward and inward motion first followed by the top of the slide. During the first operation of the season (putting the slide out) I've seen some fairly significant delay in the top of the slide starting to move but in six years of operating the slide it is still functioning properly.
    There may be a slight downward angle to the slide when out and the TT is perfectly level but if it is it is a very shallow. I try to level my TT side to side as much as possible but it is rarely perfect and regardless of which side is slightly higher or lower we've never hand any water intrusion around the slide seals (we don't have a slide topper).
  • “Need lubrication?”
    “Baby powder vs PTFE for the seals? Both seem to have good reviews. Pros/Cons of each?L
    Follow manufacturer’s recommendations.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 28, 2026
