PcolaCamper's avatar
PcolaCamper
Stink bugs!!
Our travel trailer is infested with stink bugs. They are hiding somewhere and one or two at a time show up. Last Fall we were camp hosts in NC Smokies, and they hitchhiked home with us. The last week of October they were all over the campsite. I tried bug spray which was a mistake, left an odor and only stunned them long enough to catch in my soapy water trap. The back storage compartment has a strong odor too which may be because I sprayed a lot of bug spray in it, and unfortunately the odor comes through to the inside. I don't know for sure whether the lingering odor is the bugs or chemicals from the spray. I'm stumped, don't know how I'm going to rid our camper of these creepy pests.
  • We have not had any problems with our MH, but have a lot of problems with our home. I have found Ortho defender works good. I spray under the eves and around all windows and doors. I also have a spray bottle of Dawn and water mix and spray them as i see them. that kills them slowly, so don't expect them to just roll over and die. I am not sure if the home defender would harm the fiberglass of an RV or not, so be careful. Good luck.
  • I keep two things in my 5er at all times, Eliminator Ant, Flea and Tick Killer and Ortho Home defense. Before I pull the RV into a slot, I dust the ground and area around the parking slot with the eliminator and spry the RV with home defense after I pull in. So far have had no problem.
    I know this is a little overboard, but I have been infested before, lady bugs in Indiana (these things bite!), flees and ticks in Texas and stink bugs in TN, and took forever to get rid of the pests. So far no other infestation.
    Do you spray inside and out with the home defense? I "think" I'm using the same product that is good for both. I've been very leery about spraying the outside, i.e. fiberglass, rubber seals, etc. with it. Was worried about staining and/or deterioration of seals, etc.
  • BigSur2 wrote:
    I too have this issue. I live in PA but store my camper in a woody area at a campground in VA Beach. EVERY time we go back for the weekend to camp we end up catching at least 20 or so.
    Anybody have an idea how the little buggers are getting inside? I know they can squeeze in just about anywhere but I've wondered if there is a preferred entry route. I personally wondered if they are coming in through the A/C.
    Takes time to do but can also help with many kinds of pests:
    USAToday wrote:
    Seal all cracks around windows, doors, siding, utility pipes, behind chimneys and underneath the wood fascia and other openings with high quality silicone or silicone-latex caulk.
    Remove wall and window air conditioners; weather stripping around doors and windows may help. Repair broken screens and windows.
    "You have to think like an insect," Jentsch says.
    Specifically for A/C units in RVs I'd think that in addition to caulking, a fine mesh screening material placed over the venting would do well if you are concerned the bugs are entering from that portal.
  • I spray just the outside. I concentrate on underside of the RV, tires, frame, support and stabilizers legs.
    It is easy to get to these areas before I put the slides out and setup the shore power\attachments.
  • Bayers Home Pest is the only defense I have found. Specticide and Ortho Home Defense did not work on the brown stink bugs. Bayers works, you can watch them die.
  • X2 on Bayers with the blue label. It names the Marmolated Stink Bug in the list it kills. Walmart here in Woodland, WA has a price rollback 1 gal spray jug for $7.92
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
