CincyGus's avatar
CincyGus
Explorer II
Nov 27, 2018
Storage compartment organization
I spent a lot of time over the years modifying my storage plan as we moved from a popup with a front storage compartment, to a travel trailer and now to a toy hauler. Storage is almost always at a premium in a camper so tips to maximize it along with make it easy to find what you want is what I was striving for. Nothing lights my fuse more than knowing I have something but not being able to find it. Just imagine how many times my daughter heard "A place for everything, everything in it's place"! LOL!
When we moved from a popup to a TT, I measured the dimensions of the passthrough doors on each side along with the interior dimensions of the compartment. I went to my local Walmart and found a combination of the plastic storage containers that would fit through the passthrough door and then be stackable inside. These containers would stack three high and two side by side, using almost the entire dimensions top to bottom and side to side. I believe I was within 2" on each. So using 6, I took up half of the front passthrough storage area, 3 high, 2 columns wide. I put all these on the drivers side.
We recently got a Toyhauler which has a Genny Prep Storage cage on the drivers side and about 2/3's the trailers width passthrough only to the passenger side. So a little reconfiguring had to be done along with buying a few different size containers to fit the new dimensions.
I now have 1 each labeled Sewage, Water, Electrical, Tools/lube, Kitchen, Misc.
Contents below
SEWAGE (Thin)-2 Rhino hoses, a few adapters, clear adapter. Anything that has dirty water flow through it goes in the container after it's rinsed out. No chance of contamination that way.
WATER (Tall)-Clean Water supplies (Regular water hoses, elbows, water filters and regulators).
ELECTRICAL (Tall)- Power cord, the surge protector and a 30 amp extension cord along with the electric dog bones.
TOOLS/LUBE (Thin)-WD-40, Silicone, Dry lube, hitch grease, a few wrenches, screwdrivers, hammers, socket set, drill bits, Gorilla Tape, Aluminum tape, Electrical tape.
KITCHEN (Tall)-2 lanterns, tongs, spatula, fork, propane quick connect hoses, 6 small propane tanks, grilling gloves, mantels, a propane tree that connects to a 20lb propane tank and allows multiple feeds to appliances.
MISC (Thin)-tent stakes, small 5-lb sledge hammer, claw hammer, rope, rubber bungees, misc stuff.
The Sewer, Water, Electrical and Tools all stack in my generator prep storage on the hookup side of the camper since we did not get the Onan genny. Works out well since that's the side of the camper I need everything in those tubs generally. Fit nicely with room for the crank arms for the manual slide out/spare tire and a few small odds and ends.
The Kitchen tub comes out during setup to go under a folding 6' table I setup to use for the campstove and Weber Q220 grill.
The Misc tub stays in the storage area unless I need to fix something.
This method has worked out well for me after some adjusting and deciding what I needed to have and what I just needed to have available IF. When we go somewhere to camp thats power only, I just grab the kitchen tube and the power cord and everything else stays where it is. I also like the way the plastic tubs slide on the floor of the storage area making them easy to get out.
We have done the same thing with the storage under our bed by putting the sheets, pillow, blanket and comforter for the happijack bed in a single tub for when we have guests that will be using it. Out of the way but ready at a moments notice. We have plenty of room for other things there also but area leaving it half empty for the time being.
Looking forward to hearing everyone's organizational tips so I can borrow a few and step up my game to the next level! Hope this spurs ideas or solutions to others as its all about making camping easier and more enjoyable.
  • I use a couple of clothes baskets form the dollar store to keep items organized in the front pass thru.
  • Well, IMO no sewage stuff should be kept in the same compartment with any fresh water stuff in a tub or not. There’s also a “drying” issue (rinsed or not) at least for me. Wet stuff in a closed container?
  • This is why I enjoy this forum so much. What a great idea. Adjustable length curtain rods to keep the stuff on the shelves.. Cool!!!!
  • DutchmenSport wrote:
    New 5er, had it less than 3 months now. I'm still unorganized. I'm still moving items from place A to place B and then somehow back to place A and then to place C. What I initially thought was a well placed item, ends up falling off the shelf and bonking me on the head when I open doors. We haven't figured it all out yet. Actually, we don't have that much stuff that has to stack on top of other things, even in the pass through. Now the temps are way below freezing and it's just too cold to mess with it now.
    Last trip over Thanksgiving week, discovered a new storage hazard.... the refrigerator. We had it packed full of drinks and stuff. After traveling, every time we opened the door the first time... I mean ... literally ... everything came crashing out! I'm still scratching my head on how to stop that. The refrigerator is just so big, things move around. I'm now looking for spring bars that will fit my full size residential refrigerator.
    Outside storage is no problem. It's all the stuff inside! I will say, stuff under the bed is well organized.
    You are definitely better organized than we are.
    Look in the curtain rod Dept of WM for longer tension curtain rods for your fridge.
  • New 5er, had it less than 3 months now. I'm still unorganized. I'm still moving items from place A to place B and then somehow back to place A and then to place C. What I initially thought was a well placed item, ends up falling off the shelf and bonking me on the head when I open doors. We haven't figured it all out yet. Actually, we don't have that much stuff that has to stack on top of other things, even in the pass through. Now the temps are way below freezing and it's just too cold to mess with it now.
  • Nothing I can help you with really... You are far and above more organized than I am!
    I carry all that I need, and I find I still take way too much stuff that I never use, but glad I have it if it need it!
    Most of my stuff goes in the bed of the truck. I have a flip top soft tonneau cover and a bed rug and a 6.5' bed and it holds all my "just in case" stuff.
    I store my sewer hose in the rear bumper, the water hoses go in the front storage of the trailer along with all the level boards and whatever else goes in there!
    The front queen bed lifts up for a lot of storage, but now that's just for stuff that only gets used "as needed". We used to put the pair of folding lounge chairs under the bed, but now just stack them on one side of the bed, since we always use them, they just come out first and go in last.
    Don't have to lift that bed up unless we need whatever is now stored under there.. (for some of that stuff that I never use, but glad I have it if it need it!)
    I carry way too many tools, jack stands, floor jack, bottle jack, etc, etc... and still have room in the bed of the truck!
    Anyway, it's always good to share information, as I've taken quite a few 'tips' from members here and seeing what others do while out in the field and I've helped many a camper out there with the extra stuff I carry with my "just in case stuff".. :)
    Mitch
