RoyB
Sep 06, 2016Explorer II
If it was wood no problem - I have repaired many a stripped out holes using the MOLLY BOLT (Lowes stores)...
These bolts expand back behind the wall and makes a tight repair. Then you can remove the screw... You end up with a nice metal threaded insert...
much like this pictorial shows...
Don't know if this will work with your plastic or fiberglass type wall or not...
Just a thought here...
Roy Ken
Roy Ken
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 16, 2026
