JaxDad
Oct 31, 2013Explorer III
2012Coleman wrote:MrWizard wrote:I'm sorry, but this is extremely poor advice. The presence of increased CO2 from the burning of the propane alone is cause for concern. And you can't seriously believe that the entire square footage of the interior space can be adequately vented by a small roof vent. If you use the TT's furnace, there is no need to open the windows or vents. Just having to do this sounds alarm bells in my head. Does it work? I guess so, it seems to. The big question though is - Is it safe? Negative here... Good luck to you.
i use a cracked open 'ceiling/roof vent' along with the window
no matter which way the wind blows across the roof, heat rises, exhaust from the heater rises, the wind will draw the heated air&CO2 out thru the roof vent
It's not only poor advice, IMHO, but in fact a recipe for disaster.
Yes heat rises, but CO2 is slightly heavier than air, so in the absence of anything to blow the air around or otherwise mix it, opening a roof vent will only let warm air out, not CO2.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 07, 2026
