time2roll
Mar 01, 2017Nomad
Yes the larger radiator is the prime component in cooling your drive train.
I have the two row max towing radiator in my F150 that only came on the 7700HD version not in SuperCrew back then. But due to a misprint in the oem brochure Ford was required to retrofit as part of a settlement. When I am full throttle climbing in 115 heat the temp gauge just barely moves. If I had the original radiator I am sure I would have had to throttle back plenty of times. The original radiator had just one row.
Larger radiator takes the pressure off the other coolers to supplement.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
