timmac
Mar 01, 2017Explorer
acritzer wrote:steve-n-vicki wrote:
the coolant tubes are wider and they put more fins per inch
Ok. Do you happen to know if those coolant numbers are accurate? And, if so, do they represent a significantly better operation for cooling?
Yes they would cool better, even though its only a half gal more its how the radiator blows off the heat more on the super cooler vs the standard.
Do you plan on towing above 100 degrees than the super cooler is a must.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
