Janie_Ryan's avatar
Janie_Ryan
Sway Control options - help please
We are a 2019 F150 ecoboost with towing capacity of 13,000 lbs. We are pulling a 2015 TimberRidge 28' trailer, 6933 lbs. We have a Reese equalizer hitch system (1000 lbs bars).
We are looking to add some sway control but there are many options.
We could add the Reese sway to our existing system; We could add just add a different brand of sway control; or we could get a whole new system (Camco eaz lift and Fastway E2 hitch systems have been recommended by friends) Looking for opinions to guide us. TIA
  • Lynnmor wrote:
    wing_zealot wrote:
    The only thing that matters is you get the proper amount of pressure on the bar from the friction pad. Doesn't matter how you get there.
    So then you can do a complete setup every time you connect if you play with the handle rather that follow the instructions? Tighten the handle and do the adjustment with the bolt, good grief!
    It's really pretty simple, back the handle off one turn, take the sway bar off; put the sway bar on, turn the handle one turn.
    One turn from where? Is it from the point that you bumped it during storage? One turn from where it rotated during driving? Or is it one turn from a guess? Tightening the handle and adjusting the bolt seems simple, but having two things that turn is way too complicated.
    I believe that is why many have gone to hitches that have integrated sway control, because of this extreme complication and never understanding how to adjust, and then blaming the product for poor performance.
    Yes, I agree, it seems to be way to complicated for you.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
