L_and_J__Waters's avatar
Jul 06, 2016
Sway Issues with 2013 1500 Suburban
I'm having sway issues with a recently purchased 2013 Suburban LT 2wd w/8100# tow package (K5L) towing a 2000 26' Coachman w/ scale weight of 6000 lbs. Side winds and trucks are now a pain in the boat. Got about 600 lbs tongue weight with a 1000 lb Equalizer.
Scale weights are front 3120, rear 3340 and trailer 5440. Burb alone 5900 lbs. Hooked up, front end within 1/4 inch, rear end drops 1 inch and the bars and trailer are level. I've towed this same trailer about 20,000 miles with a 2004 Tahoe and a 2005 1500 Suburban(with Bilsteins) without any problems. RPO code indicates ZW7 premium smooth ride, but it does not have the nivomat shocks. When a dealer looks up the part number via VIN, it does not call for the special nivomat shock, just an $80 shock. Been trying to find out if GM added the ZW7 code without the special shocks, but not much luck with dealers or GM customer service. Also, the nivomat system uses a weaker rear spring. I can't seem to get past the VIN parts listed for the vehicle. Bottom line, I want to resolve the sway issue, but not quite sure where to go from here. I'm used to towing with a fairly light touch on the wheel and I'm not enjoying the tow since trading vehicles.
  • You might need shocks on your Burb. I towed with a 1500 Suburban our 18 foot Dutchmen. I ended up putting stiffer shocks on the rear, which took care of a lot of wiggle on rear when towing. Never noticed anything when not towing, but when in-tow, she wiggled all over. New shocks made all the difference. (just something to consider ... a suggestion only.)
  • Tires are P265/ 70R17 Firestone Destination LE2
    They are listed as light/medium truck duty at Firestone
  • Put a little more weight on the trailer's tongue. You can go up to %15 of the trailer's total (and actual) weight.
    Ron
  • Check your tires, are they 'P's with soft sidewalls. Up grade to 'E' tires.
Looking for advice before your next adventure? Look no further.25,103 PostsLatest Activity: Jan 21, 2025
