Ron_Gratz
May 24, 2013Explorer
Jack,
Here's the problem with the numbers:
The indicated tongue weight using TV only data and TV+TT with no WD is (3080+3700)-(3500+2740) = 540#.
Since the brochure hitch weight is 597#, it's quite unlikely that the loaded TW can be 540#
The initial loss of 420# on the steer axle is consistent with a tongue weight of about 1020#.
The initial gain of 960# on the drive axle is consistent with a tongue weight of about 680#.
Changing the "TV only" steer axle load to 3360# gives:
The indicated loaded TW is (3080+3700)-(3360+2740) = 680#.
This value is more consistent with a brochure TW of 597#.
The adjusted initial loss of 3360-3080 = 280# is consistent with a TW of 680#
A TW of 680# plus the TT axle load of 5080# gives a TT weight of 5760#.
The corresponding TW% is 680/5760 = 11.8%.
For comparison the dry TW divided by the shipping weight is 12.0%.
The adjusted net load reduction on the steer axle would be 3360-3280 = 80#.
Where were you positioned when the three sets of loads were measured?
If you were in/on the truck for some of the weighings and somewhere else for others, that could explain the discrepancy.
Ron
Ron
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
