SpoiledRotten wrote:
Thanks for posting, ryanallie.
Hi there "Spoiled Rotten".
Our pleasure. it really is a super great Fan to have. Espicailly since it use such a little little bit of power.
Our whole Motorhme is mostly set-up for Boon-Docking. All of our lights inside our Motorhome and inside all of our outside compartments are all "LED Lights.
Winter time is some of the best Boon-Docking times there are. And we don't even have a Mulit-Season Motorhome.
We don't even use our Motorhomes Furance, as they do nothing but suck down Propane and suck down the Propane. I do make sure that it does work in case of an "Emergency".
But we use "Catalitic Propane Heaters"..We can even run past our Motorhomes 30 amp limit with no problems. Besides our 5.5 KW "Built-In Generator". We also have a "Pair of Twin Honda EU2000i's, and the "Paralla Kit" and the "Extended Run Tank". And plenty of 12 guage Extendsion Cords, we can be out in Temps just about as cold as we chose.
There is a lot you can do to a regular so called one season Motorhome, to make it as comfortable and enjoyable as you choose to be. Good Luck. Happy Travels. Dan & Jill. You learn a lot after over 46+ years as "RV'er's and Boon-dockers". You'l hear a lot of people tell you about how much moisture you will have using Propane Heaters. We hardly ever have any at all. We have it done to a fine since. The Oly Wave #6 and the Oly Wave #8 Propane Heaters are great Heaters. They are easy on Propane, and don't use any Power at all.
