northmeck0255
May 07, 2013Explorer
Forget slide leaks. They are pretty rare and it would only be a little bit of water anyway. The big flood hazard is the on board plumbing, in particular leaving campground water hooked up and turned on. Many a sad guy has returned from dinner to see water coming out the front door because someone left a faucet open or a pipe burst.
We use campground water ONLY for filling the on board tank. If we leave, we shut off the pump and bleed off the pressure. If in a FHU site, always leave the gray valve open unless saving up gray water to flush hose after dumping the black.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
