silvercorvette
May 08, 2013Explorer
northmeck0255 wrote:
Forget slide leaks. They are pretty rare and it would only be a little bit of water anyway. The big flood hazard is the on board plumbing, in particular leaving campground water hooked up and turned on. Many a sad guy has returned from dinner to see water coming out the front door because someone left a faucet open or a pipe burst.
We use campground water ONLY for filling the on board tank. If we leave, we shut off the pump and bleed off the pressure. If in a FHU site, always leave the gray valve open unless saving up gray water to flush hose after dumping the black.
If I am hooked up to water I have a pressure reducer to prevent burst pipes. If I were leaving the camper longer than it takes me to walk my dogs I would stay connected but turn off the valve.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
