Bendmac's avatar
Bendmac
TPMS on trailer tires
Greetings...
2016 24' FBS; came with Goodyear Endurance tires. I've been running max pressure (65#, marked prominently on the sidewall) when towing.
I recently installed an inexpensive TPMS that plugs in to the power point in the TV. This uses sending units that screw on to the trailer tire valve stems...pretty small and lightweight so no too worried about messing up the valve stems. The receiver shows current tire pressure (in bar or PSI...I use PSI) and tire temperature. (TV is a 2014 Ford F150 EB with built-in TPMS for the truck itself but nothing being towed).
That said, what say ye to min/max pressure thresholds for the trailer tires? Right now I have it set on 75# for the high threshold and 50# on the low.
As far as tire temps...I hunted around but couldn't find anything to suggest a "normal" operating temperature for the Endurances. The unit only reads out in "C" and has a minimum setting of 70C (158F) and a maximum of 90C (194F). Any suggestions on what to set that upper temperature limit alarm at?
Cheers,
Bendmac
  • I have my TPMS set at 10% below and 20% above the pressure I plan to use. I leave the temp set at what it came from the dealer with.
    My tires are run at 80psi so I have my alerts set at 72psi and 96psi.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
