CHD_Dad's avatar
CHD_Dad
Trailer Tire Pressure/Temp/Speed vs. failure ?
I was told that speed is a big killer of trailer tires along with age, overloading, hidden damage, etc. but the big reason they tell you to stay at slower speeds is to keep the tire from overheating or getting damaged.
After a blowout on my first TT that had the cheap Chinese tires I decided to get a TPMS system for our newest TT, especially since I can only run small 14" tires on a fairly decent sized camper (30' long, 6600# loaded). Its one of the models that tells you each tires pressure along with the temp.
I have used this system now for several trips and the ambient temps ranged from the 50's up to to the high 80's. Roads were both asphalt and concrete.
I am not seeing the issue with speed vs. pressure or temp increases using this system. I can tow at 50mph or 70mph and the pressure may change 1-2psi max between those speeds. I air at up the max 50psi cold before the trip. After driving a good distance my tires may be at 55psi - 59psi depending on road surface and air temp. Those seem to have far more impact vs. speed. I ran an hour at 60mph and then got up to 70mph so I was keeping up with the big rigs who kept passing me and the difference was negligible at best. Same with tire temps, there was just a small change as expected with the pressure increase.
So what is the reason for keeping speeds at a low 60-65mph? I always read doom and gloom awaited those that sped past those speeds unless they were running tires like LT truck tires or an over rated tire. The biggest hit seems to be to my gas mileage. I dont plan on pulling at 80mph even when all the cars are going 80+ (the main highways around me are all 70mph) but I would certainly rather keep up with the big rigs at 70-ish or so vs. being passed by them constantly.
Towing setup is in my sig. Tires are Maxxis 8008.
