Cecilt's avatar
Cecilt
Truck Tire Pressure
I have been running 80 psi cold in my front and rear truck tires. Truck is '09 F-250, crew, 4x4, with factory 20" wheels. Tow a 9500lb loaded TT. Not sure why but just thought it was safer to max the pressure when pulling this much weight.
Looked at the door jamb and it says to use 65 psi front and rear. No reference is made to if truck is loaded/towing a camper. I think this sounds low. I did air down to 75 rear and 70 front and it felt much smoother going down the road. If you are towing a decent amount of weight do you "trust" the sticker or rely on the sticker when you are just driving without towing? tks
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
