BB_TX
Dec 20, 2016Nomad
When mine would not hold water, I replaced the seal around the ball. Not difficult, at least on mine. Mine is a two piece bowl, with a metal band around the middle holding the top to the bottom. I loosened a screw and removed the band. Disconnected the water line. And lifted the top portion of the bowl off. Then I could get to the seal. I did notice the seal was not exactly centered over the ball. So when I installed the new seal, I made sure to center it after cleaning the ball and surrounding area well. Put top back on. Replaced metal band. And it holds water fine after several years.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
