weathershak
Dec 20, 2016Explorer
DutchmenSport wrote:
For the one not holding water, try this first.
Get a good toilet brush and brush around the rubber where the slide valve slides into. It's possible a bit of crud is stuck on the rubber not allow a good seal. It's very common for this to happen. Easy fix, just run the brush around the rubber in the hold. See if that help.
No help on the other problem. Good luck.
X2 And oh, throw out the tooth brush. :)
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
