Parhole1's avatar
Parhole1
Type of Hitch to Purchase
I have a TV- 2014 Dodge Citadel, 5.7 hemi. 3.09:1, GVWR 7100 lbs.; TT-2014 Sport Trek, 250VRK, UVW 5270 lbs., Hitch Weight 500 lbs., Carrying capacity 1230 lbs., GVWR 6500 lbs. -- I have 4, 300 to 400 mile trips under my belt. TV has plenty of power and control with a 10K generic WDH & friction sway control. Problem is we feel some movement(sway) with 18 wheelers and Diesel Pushers passing. This is uncomfortable and somewhat daunting. I am looking at the Equalizer 10K 4 point sway control hitch. This hitch seems to be able to handle the movement and is reasonably priced $600.00. OR I am looking at the Hensley Club (smaller version of the Arrow). 6000 lb. rating, tongue rating 600lb. I am not sure because of the ratings of this Club that I am at the limit of my ratings and will it be OK. The Arrow is a few hundred more but rated at 14K....Seems an overkill. Either Hensley's is a sacrifice of one camping outing with it's price tag and my inability to set up and install.
So the problem arises as in life what decision to make. If the Equalizer will not provide a comfortable ride then it must be Hensley and if Hensley do I get the Club or Arrow? I am requesting some experienced RVer's with either hitches and my ratings to offer their best opinions.
  • Primary causes to what you are feeling are:
    1. Bow wave - A lttle push pull is normal. The hitch won't get rid of 100 percent. A lot of this is not normal.
    2. Hitch not adjusted propperly, or underrated - If the hitch is not restoring enough weight to the front axle of the tow vehicle, you could have subconscious hand movement, which causes the truck / trailer combo to wiggle. Your 1000 lb hitch suggests, being under rated is not your situation. Scale weights will tell you about any adjustments needed.
    3. Unbalanced loading, or, too light on trailer tongue weight - Scale weights?
    4. Towing trailer with nose up attitude - Check hitch ball height.
    5. Overloading tow vehicle - Check your payload. Subtract weight of all passengers, cargo, WD hitch, and actual trailer tongue weight, from available payload. If you're in the hole, a new hitch won't fix that. Passenger "P" rated tires have softer sidewalls than truck tires. It's possible, you're feeling sidewall flexing. You could spend a couple grand on a hensley and still have that problem.
    Before you throw a bunch of money at a new hitch, check your actual weights, payload (everything and everybody's weight in or on the vehicle, count against this), tow rating, tire pressures, and hitch settings. Could be something simple as lowering the hitch ball, pumping up the tires, moving up one link in the chain tension, or re-arranging some weight in your loading. Then decide on if, or how much you want to spend on a hitch that may or may not improved your ride.
  • Whatever you get, get something "hefty" now with this purchase. That way, "when" you change campers and tow vehicles (an you will!) ... you've already made the investment and won't have to re-do it to go heftier if you go minimum now. Just my advise!
    I do think most push-in-out sensations coming from passing semi trucks is because the tow vehicle is too small. Same trailer, same weight distribution, but a world of difference when towing my 18 foot Dutchmen Sport with my 1500 Chevy Suburban, and then we changed to a 3500 duly (gas) Chevy. Never had that push-pull-again ... there again, same trailer, same weight distribution hitch. Just my own experience speaking here. Your's may be different.
  • Maybe you dont have your WD hitch set correctly...
    What psi do your tires state? I run mine max 50 psi and that little push sway minimized...
    Ill check your specs on the truck but if your WD not set right your front end may be floating..
    Whats make model of your WD?
    Have you been to the scales?
Looking for advice before your next adventure? Look no further.25,107 PostsLatest Activity: Jan 29, 2025
