Sounds like should be fine, couple of things to think of.
LED lights if you are up at night in the fall - cheap upgrade.
These are most of the ones I used, you do not have to get ones this bright.With 220 AHs of AGM you may want to consider a larger charger, the $delta for extra amps is not much. On the other hand if you plan on solar power only, as may be the case, then 45 AMPs should do.
An example of prices.Note even with AGMs it will be hard to use that extra charging current unless you have a very low resistance to the batteries (something the stock setup likely does not have).  This suggestion totally depends on your intended use.
