craig7h's avatar
craig7h
Nomad II
Jun 13, 2016
Using 4wd to slow down
I was reading the last issue of trailer life, the article a couple wrote about looking for a new truck. In the article they said that when going down a step grade they will put their truck in 4wd low and low gear to help slow down. I would like to know if this is common practice. I would have never thought about doing that, is this something that the trucks transmission can handle.
  • I do not know of any transfer cases that allow you to get into 4WD low over 5mph. You can try, but I don't think the electronics will let you.
    I would be careful using any transfer case design 4WD on dry pavement. Consult your vehicle owners manual first as there are several types of systems.
    Use a lower transmission gear, not transfer case to slow down long downhill areas. If you have an automatic in the last 20 years, they won't let you overrev.
  • I have never heard of that but that doesnt mean anything LOL. For me to go into 4low I would need to be stopped, then put it in. Any of the 4WD's i owned were the same way, there is only shift on the fly to go into 4Hi. I use the tow command system that keeps it at the speed i want to without using the brakes. I think all of the big 3 have something to do this, tow command system, exhaust braking etc...
  • Unless the truck has AWD (center differential) you'll eventually wind-up the drivetrain and start to hear a lot of grinding and popping sounds. All 4WD manufacturers caution against using 4WD on dry pavement.
  • Using a lower gear, fine. Using 4 low is not necessary. Probably not even a good idea unless you are descending a very steep decline on dirt, gravel, or rock. Certainly not needed no pavement.
  • that is one of the most asinine things I have heard!!! Talk about putting a horrible strain on 4x4 parts!
    Gear down, same gear down as up and use brakes sparingly! If you are lucky enough to have an engine brake use it
    Chris
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 28, 2026
