Community Alumni
Apr 30, 2013I have the webber BBQ and it has its regulator on it and I connect it to my RV after the main regulator and it woks just fine. I did not need to remove the regulator on the BBQ. There was an article in one of the GS publications that stated that the main propane regulator operated at 11 inches. It also stated that some appliances that have there own regulator such as stove tops or other appliances were made to run at a lower pressure than 11 inches so to remove one of hose IMO would run more pressure through that appliance than it was designed for. As I said my works fine using a quick connect after the regulator.
JimR
