Caryite
Nov 25, 2016Explorer
garyhaupt wrote:
You will be mounting the seals onto the valve assemble then sliding that into place and fitting the bolts/nuts. I would NOT suggest adding any glue. If you are worried about slippage, perhaps a dab of Vaseline. But that seal just sits right in the valve assembly.
Check out 5:10-5:20 of the below video. So I should use vaseline to keep the seal on the lip of the valve flange fitting?
Valterra valve replacement video
Thanks for the replies today. I haven't done anything yet as I decided to focus on installing my new Husky 3000 electric jack today once my manual one died.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
