fdemers's avatar
fdemers
Water damage on floor
Hello,
I own a 99 Keystone Hybrid. Three years ago I did a complete floor and sidewall replacement. Everything has held up well, however, I just noticed some water damage on the floor toward the front of the camper. The water is not coming in from the roof. All of the caulking around the front fold out looks good. The underside (belly) of the camper is completely enclosed and sealed. Anyone with a Keystone hybrid had any similar issues??
  • Not a Keystone but I've had water get in at the gasket hat goes between the bunk door and the aluminum frame, you can check it with a dollar like a fridge door. Also the front upper marker lights can leak letting water in the wall. Mine also has a small front storage area that runs under the bunk going from side to side, the door gaskets get squashed down. The marker lights would be my first guess if the roof looks good.
  • i suggest you ask a similar question, in the Hybrid Forum here.
    many don't know what a Hybrid TT is.
