- hammer21661Explorer
Ronhoward wrote:
What was it?
Got it fixed but had to pull tank out
Thanks for the ideas - RonhowardExplorerGot it fixed but had to pull tank out
Thanks for the ideas - RonhowardExplorerWhere would the check valve be? I have the bypass valve figured out I tbink. I will try to find the I check valve
- PapPappyExplorerBad check valve, or is there a valve in the bypass system that is in the wrong position? It can get confusing?
Are you getting pressurized water coming out the pressure vent valve on the outside of the water heater? This would indicate that you are getting pressure into the tank, and that the "out" line is plugged or a valve is shut.
When testing, make sure the water heater isn't on, to avoid getting burned. - bob213ExplorerMight be the check valve on the hot side of the water heater.
- ibyersExplorerBad check valve on hot water heater.
- hammer21661ExplorerIs the heater tank full? if it were full it should not affect the cold side.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
