allenm's avatar
allenm
Water Pressure
This is not a huge problem - just a bit annoying, and I've never noticed it before. I'm connected to campground water and the pressure is a little high. I'm using a pressure regulator at the spigot. That feeds a 25' 5/8" hose which connects to a water filter connected to my trailer.
I'm snow-birding in Florida. The temp has been ranging from 50s at night to 70's in the day.
Here's the problem - Every water fixture inside starts out with good pressure and flow. Then after 5 seconds or so it drops way low. Not so low it stops but low enough to be aggravating.
If I remove the pressure regulator at the spigot, I get continuous great pressure and flow. No slowdown. But the pressure is really too high. I found a couple faucet connections dripping without the regulator in place.
So, I went to CW and bought a high flow (50-55lb) regulator and installed it in the same place at the spigot. Good flow but the pressure drops off after say 15 seconds, whereas it dropped off at 5 seconds with my original regulator.
My question is whether it's normal for regulators to drop pressure after 5-15 seconds? I've been rv'ing 10 years in 3 different units and never noticed this before.
Is it maybe the pressure buildup in the 25' hose that gives good pressure for a few seconds?
How may screens should be in a supply line? I have one in the regulator and one in the filter. All are clear.
Sorry for the novel...
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
