mobeewan
Aug 26, 2020Explorer
I bought a spare sure flow pump for the trailer and mounted it to a small cutting board. I attached a 2 pin plug for power and added fittings with hose barbs so I can pump from a container into the water tank fill on the trailer. My winterizing tube is long enough that I can insert it into a water jug and draw from it to supply the trailer using the trailers pump just the same as if it was my water tank. This came in handy when my tank under the trailer started icing up in the wintertime.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
