Lynnmor
Aug 26, 2020Explorer II
Your trailer has a pump, make some minor changes to the plumbing and use it. On mine, I had a winterizing hose that I connected to the hose behind the city water inlet with a tee, if necessary add a similar hose. I gutted the check valve out of the city water inlet and added an inline check valve inboard of the added tee. I bought an 8 gallon Hydroller portable tank with wheels that I modified with a dip tube, but any tank will work.
No lifting, funnels, wires, switches or battery connections. I can't understand why folks won't use a pump that is already there. A check valve, clamps and a tee were the only purchased items.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
