aslakson wrote:
The Escapees club has a couple of 4-wheel weigh stations at some of their parks, and has a traveling unit that goes to many of their rallies. What we've done is find a scale that's not too busy and flat to the ground. First drive thru and get a total rig weight and individual axle weights, then drive thru again, offset enough that only the wheels on one side get weighed. A little math will then give you the individual wheel weights.
al
Sounds like a great idea, except it is extremely hard to get repeatable numbers. Each time you side step the scale to reweigh if you move the rig a few inches from where you weighed the last time the numbers will change. Those platform scales are not designed to be side stepped that way. Much better to find a guy with the individule scales and weigh correctly at each tire location, 4 corner weigh.
