jgos929 wrote:
Im interested in how you fixed the flexing. If you could point me in the right direction as far as what I need. A good buddy of mine is a fabricator and master welder and assures me he could weld me in some bracing if need be. Thanks
The lower flange on the RV industry I shape frame rails is really weak. If you unhook the spring and put a 12" adjustable wrench on the spring hanger with very little effort you can flex the entire lower flange. Your crack lines are from frame flex.
Here is what I did to correct the problem with hanger flex. However if you notice I already had 2 x 2 square tubing inside the frame down at the lower flange on the inside and I had a gusset on the middle equalizer. Yours has no gussets at all and may be missing 2 x 2 cross braces.
TT Spring Hanger Stiffening (Long, lots of pics)Here are the cross 2 x 2 square tubes. These pics are before I added my cross tubes at the hanger and the frame gussets. These are more stock from my TT manufacture. I was looking for these on yours and there was no good pic to tell.
Rear spring hanger area
You can see it left to right here
Front spring hanger. This tube is burried under my tank cover, but it is just like the rear one
The equalizer area spring hanger. Here I have a fresh tank angle iron and the end of the enclosed tank compartment wall
These frame supports on the inside need to be down at the lower flange.
In my case I have 5" long spring hanger and the 2 x 2 cross tubes helped the frame but did not help the spring hanger lower flange flex. So I beefed up the hanger, put reinforcing tubes inside the hanger and then cross tubes on the hanger. I also needing and 1 1/4" lift so I made longer hangers too.
If you show these to your fabricator he can reproduce this using channel iron of more 2 x 2 x 1/8" wall tube. He is going to have to fix the frame cracks and should add the 1/4" x 2" flat bar gussets from the lower flange to the vertical web of the main frame rail.
Hope this helps and good luck
John
PS, the frame crack you have is semi common
Here are a few,
Fisherguys KomfortThis one is the worst I have seen. Maybe this will make you feel a little better... It can get worse...
frame cracks
