dnhx
Aug 15, 2014Explorer
Weight of hitch for calculating tongue weight
We have neither TT or TV,so I am trying to determine if the Ford Expedition will work for some of trailers we are looking at. A F150 will not fit in our garage, so that is out. Expedition: max tongue load 920 lbs with WDH, GVWR 7300 lbs, GVW ~5800 lbs, passenger & cargo will be around 500 lbs, which leaves 7300-5800-500 = 1000 lbs for the trailer tongue weight.
The heaviest TT we are looking at is 5300 lbs dry (26' length), just two of us and dogs, so I would think stuff + propane and batteries would be about another 1000 lbs, for a total of 6300 lbs. Given the max tongue load rating of the TV, the tongue weight distribution could not exceed about 14% which is ~ 900 lbs.
As you can see we are getting very close to the limits of the TV, so I want to be sure I do not exceed them before buying it or this TT. As far as calculations, the only thing I am unclear about is how to account for the weight of the actual hitch. Since we are new to towing, I am considering the Pro-Pride hitch, which I understand is around 200 lbs. Does the weight of the hitch add to the TV payload or is the weight considered as part of the trailer weight?
thank you
thank you
