Ralph_Cramden
Aug 12, 2018Explorer II
BeerBrewer wrote:
I was at that Web site and when I read the technical specs it said "MADE WITH CARB PHASE 2 COMPLIANT LAUAN". As stated above I'm not sure what that is but it sounds like lauan plywood that meets some CARB (California Air Resources Board) spec. Now I probally missed it, but no where on that spec sheet did I read that it says it was wood free. Where did you read that?
Crane Composites Website.
Noble® Select | NS
All-Composite Wood Free Sheet Glass Panels
An all-composite, wood-free exterior panel with superior surface and weathering performance. Noble Select is designed for both laminated and free-hung wall applications and is preferred where full-body paint is required.
Of course the fiberglass panel itself is "wood free" LOL, not sure why they would even bother to state that. Then Winnie buys that product from Crane, and laminates it into the wall panel using Luan plywood for the substrate layer and inner wall surface.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
