BeerBrewer
Aug 13, 2018Explorer
I'm not really concerned with wood and/or plywood being used in Travel Trailer construction. I know plywood is routinely used in walls, floors and roofs and I'm okay with it, as long as I know it a head of time. I don't like it when RV manufactures have lauan or other "rottable" wood materials laminated into the their fiberglass sidewalls and they then give it glitzy names like "TuffShell" or "Vacuum Laminated Roof and Walls". This is nothing more than marketing hype that unfortunately gives the impression that their walls would never rot or delaminate, when we all know that isn't true. A side from the boarder line misleading advertising, my main issue is that if the lauan or wood that is laminated inside my TT walls gets wet due a leak and starts to delaminate there is nothing that I can do to fix it. On the other hand if a traditional aluminum sided TV gets wet and starts to rot, I know that I can fix it. Odds are it wouldn't be easy, but I know that I have the carpentry skills to repair it. I can't say the same for fiberglass/Lauan laminated sidewall, this sounds like an expensive job for a pro RV Tech, if it can be repaired at all. From what I've read a lot of RV owners don't know that they have a leak until after they notice the delamination occurring, which is often too late.
I was interested in TTs that use the Azdel material because it is very light, supposedly is not pron to delamination (at least that is what I've read) and it resists mold and mildew.
I honestly don't know what type of TT we'll end up with but I can honestly say that we'll likely shy away from TT's that have wood materials laminated into the sidewalls.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
