westend
Aug 14, 2018Explorer
If you're concerned with delamination, buy an aluminum sided trailer. In a fiberglass walled trailer, the bond between the subsurface and the fiberglass is only as good as the adhesive and the construction process. Many Azdel composite walls delaminate because the adhesive is water soluble so a leak means delamination.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
