Ralph_Cramden
Aug 15, 2018Explorer II
westend wrote:
If you're concerned with delamination, buy an aluminum sided trailer. In a fiberglass walled trailer, the bond between the subsurface and the fiberglass is only as good as the adhesive and the construction process. Many Azdel composite walls delaminate because the adhesive is water soluble so a leak means delamination.
Thank the EPA......and low VOC regs.......
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
