GaryS1953
Aug 25, 2022Nomad
JRscooby wrote:Matt_Colie wrote:
Gary,
I don't know where you are in Michigan, but we have bearing stores all over the place. What you do need to do is get all 5 numbers. I don't know about your unit, but it may well have different numbers for the inner and outer bear sets and each of those is two part numbers. The seal is a third.
I hope the spindle isn't damaged. That often happens when a bearing goes bad.
When you get all 5 numbers, use a marker to write them inside a cabinet door so you will have them next time.
Matt
I carry all bearings and a seal to do 1 wheel. Plus in the garage I have enough seals to do all my trailers, and shoes springs and magnet for 1 wheel per trailer. If I decide it is a nice day to service a trailer I don't want to hunt parts.
That is a great idea. I'll be going back to my dealer tomorrow and buying bearings for 1 or 2 wheels to have in the trailer at all times for just such a case. We were very lucky this time that we had just arrived home when we discovered the problem. Also, so lucky that we had a double axle trailer.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
