RCMAN46
Aug 26, 2015Explorer
Same for a train. There have been people pulled from a platform into the passing train.
The blowing across a piece of paper as described in a previous post is the best example I have seen.
I have found motor homes do the most sucking. I suspect it is due to the very low ground clearance they have compared to most semi's.
Watch a Nascar race. They talk about the side draft at the higher speed tracks.
When it is the worst is with a cross wind coming from the side that a truck or motor home passes. First you have a 20-30 mile wind pushing from the left then all of a sudden there is a suction pushing towards the truck then when it clears a bunch of turbulence and a 20-30 mile wind pushing again.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
