wnjj
Aug 27, 2015Explorer II
Vulcan Rider wrote:
If you increase the amount of air in a (somewhat) confined space, the pressure goes up, not down.
The wake from each vehicle is already compressed somewhat; add the two together and the pressure is even higher.
At or near the front of the vehicles, I agree that the pressure will add up to a higher one but the high pressure at the front will cause a pressure gradient from front to back (where there is much lower pressure or even a vacuum). This in turn accelerates the air to a higher speed within the "tube" which reduces the static pressure throughout the space between the vehicles. This is why there's a bow wake pushing you away followed by the suction pulling you in when another vehicle passes you.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
