tkamsal's avatar
tkamsal
Wiring one air conditioner to use 20 amp outlet
I have a 1997 Winnebago Itasca Suncruiser with a 5k Onan generator. The RV has one 30 amp plug. However, both air conditioners will only work at the same time if the generator is running. I would like to be able to run both generators off of my RV park electric outlet which has a 30 and a 20 amp outlet. I read once that one could rewire the unit to be able to run one air conditioner off the 30 amp outlet side and the other by adding a separate 15/20 amp cord and plug off the unit which could then be plugged into the park 20 amp outlet. It was wired in a way that the generator would still run both air conditioners at the same time. Anyone?
