ScottG wrote:
I think some get hung up on the wheels rating but I suspect the rating is just a minimal spec.
A welded metal wheel that says 50 psi is probably just tested to that limit. It's still a solid metal piece that's welded just like any wheel.
That same wheel could probably take several hundred pounds of pressure without exploding, cracking or otherwise failing. (same for aluminum wheels)
It doesn't mean the wheel will fail at any pressure above 50 PSI.
and....
I'm not. If there were load range f tires for my wheels, I'd install them on my wheels and air them up all the way without a doubt.
It is the spec...not max, nor min...it is the specification for a dynamic application
Within that specification are dialed in margins by design
Your example is for a static condition and again, just the specification without any min/max notation
Dynamically...that one tire/wheel takes, say: a 2018 F150 with a GVWR of 7,000 lbs...going 100MPH (typical for trucks dialed in max speed before the computer shuts down fueling), on a curve (so most of the weight and energy is on the outside tire/wheel), hits a pot hole...many, many, many occurrences over the life of that tire...
Now step back to where that tire/wheel is before setting off on this test drive...
Air it up to a high as someone said for their "F" load range tire, which is 95PSI
Vs "P" class XL tires max rating:
Tire Tech: Tire Specs Explained: Maximum LoadArticle on this topic from TireRack.com, 2 pages
Click For Full-Size Image.
If interested in learning (have just blocked those who are resistant to that, but they show up when expanding the thread to see what has been said) check out this book I've been reading and referening for years and years on my boy racer forms (closed to non-members)
Understanding the Influence of Pressure and Radial Loads on Stress and Displacement Response of a Rotating Body: The Automobile WheelWithin that book are these images explaining how PSI inside the tire acts on the wheel....
This one has to do with the beam loading on the wheel rim
