DrewE
Jan 14, 2015Explorer III
MEXICOWANDERER wrote:
Thanks for realizing I have truly lousy internet here with TelCel using the cellular. Looks like I have to abandon The Great Plan.
Oh well the Cheapos will work.
It's difficult finding a 120vac / 36-vdc converter that is very inexpensive. For LED lighting.
If you don't need isolation from the line voltage, I think you could in theory wire up a 48V transformer as an autotransformer (connecting the primary and secondary in series with the proper polarity) that should be relatively close to 36V rms nominal output. Add a bridge rectifier and a filter capacitor for a super simple unregulated linear power supply, and a little fiddling with the loading and maybe some current limiting or voltage dropping should get you something that's adequate. You would need to derate the output current of the 48V transformer...by about 30% if I'm doing my math properly (since the secondary winding now carries both the input and output current).
