- RJsfishinExplorer
Tom_M wrote:
I have a one gallon compressor which looks similar to the one pictured and my 300 watt inverter runs it fine.
And 2 amps ?
Thanks, good to know. - Tom_M1ExplorerI have a one gallon compressor which looks similar to the one pictured and my 300 watt inverter runs it fine.
- azrvingExplorerThey appear to pull 2 amps so it shouldn't be a problem. Great price.
- RJsfishinExplorer
JaxDad wrote:
It will probably start and run from empty, but you might need to unplug it and release some air before it will restart when the limit switch calls for more air.
Maybe, but seem like some have an unloader valve for a no load start? - JaxDadExplorer IIIIt will probably start and run from empty, but you might need to unplug it and release some air before it will restart when the limit switch calls for more air.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
