landyacht318's avatar
landyacht318
"10 watt" LED
A while ago, as an experiment, I bought a 12v outdoor landscape light that claimed 10w warm white.
TO NO one's surprise it did not consume 10 watts, and while it did respond to a PWM LED dimmer, the range of adjustment was pretty poor so I did not use the dimmer thereafter.
It failed today. I'd estimate no more than 600 hours maximum total use.
When I feed it 13vDC, the LEd just flickers not close to coming on at full brightness. When i remove 12vDC is flickers once a bit brighter then flickers for a few seconds longer.
Now this was inexpensive, but to me it seems like a fairly good waterproof design, which can have a better LED attached to the fairly substantial housing/heatsink. with little effort. It did not get hot, merely warm, when it worked properly when new.
The circuit board driver does not have that burnt electronic smell, but could be blown for all I know.
They make a "20 watt" version of this light which employs the same housing, so I would be game to upgrade the LED emitter and electronics even if it costs more than buying a better product.
I could also add even more heatsinking.
Call it a learning/ keep it out of the landfill type of project.
I'd love to this housing contain a very powerful LED 12v light that responds nicely to a PWM dimmer, even though I do not really need one.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I have purchased many lED's some from E-bay, (Assorted results none 100% happy but Ill settle for 90) Some Amazon (So far So good, in fact I'm sitting under a 5 meter strip of Amazon Led's for less than 10 bucks as I type. I cut the roll into strips, tape 'em to the backing plate on my Thin Light Florcesent .. after removing all the Florcesent sockets and ballast, and they are N*I*C*E*!!!!!
    Long lasting too
    and some from other sources where I can check first, (Expensive).
    My recommendation is make a small purchase and if it's a good supplier. TAKE NOTES and buy more.. If you want the Amazon page for the COOL WHITE lights I use (I like Cool not Warm) ask and I'll see if I can snag it from my order history.
    I don't sell 'em. I just buy 'em.
  • Too many times I've seen those "packaged" drivers being nothing but junk inside. Call me a snob, but I don't buy anything power LED related off eBay, too much scamming going on. Digikey, Mouser and Future Electronics satisfy all my needs, and really aren't that expensive for genuine parts.
    Ok, I do buy their LED flood lights, throw the guts away and re-use the housing. Domestic cast/machined housings are stupid expensive.
  • CHIP
    Power Supply
    BETTER
    https://www.ebay.com/itm/10W-20W-30W-50W-100W-Waterproof-High-Power-LED-Driver-Supply-LED-SMD-Chip-Bulb/162000234100?hash=item25b7f76674:m:mrAkcjQIpzv6_W3UHOODO7A
    • Make sure (4) 3.5 chip screws are not stripped or bottomed out
    • Insure flat chip mounting surface. I like scuffing with 80 grit
    • Use SILVER heat sink compound -- it really does lower chip operating temp.
    https://www.ebay.com/itm/Top-Quality-SILVER-Thermal-Paste-Compound-For-CPU-GPU-Block-Heat-Sink-4-5w-MK-1g/252492064905?hash=item3ac9b32889:g:mpgAAOSwARZXpf6G
    After repairing several dozens of these lights, I seem to have ironed out the bugs. None of my upgrades have failed in 6+ years...
    But none of the above addresses the issue of dimming. Use a 5-watt chip and matching power supply?
  • I do agree the best part of a cheap Chinese LED flood light is the housing.
    To rebuild it in a fashion that supports external dimming a resistor dropper is your only choice. Any kind of active circuitry, linear or switching would be confused with an external PWM supply.
    The driver pictured might be a linear constant current driver, and the big capacitor is the reason for poor response to your external dimmer.
    The downside to a resistor dropper is extreme energy waste, especially for a high power LED.
    A switching driver with built in dimming and external control support is what I recommend. Like a Luxdrive Buck-puck. It comes with an analog dimming input you can connect a pot to and use as a brightness knob.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 05, 2025
