cpaulsen's avatar
cpaulsen
110 outlets
2018 Montana...…..mo 110 outlets in front half of 5th wheel . Thought it was circuit breaker...….not! Then GFI in bathroom.....not again!! Anybody have any ideas. I ihave to power going to the circuit breaker.
  • Had a strange electrical problem one time and it was GFI even though tested good.
  • Did you check for another GFI?
    Do you mean you have power coming out of the circuit breaker going to a receptacle?
    If you have a wiring diagram, check for power at the first receptacle. It could be a bad connection or broken wire. If you don't have a diagram I would start checking the closest receptacle.
    If power is leaving the circuit breaker it's stopping somewhere at or before the first receptacle.
    Get out your multimeter and start looking.
    Did you tighten the screw holdimg the wire in the circuit breaker?
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 28, 2025
