SlownsyExplorerFeb 28, 2017110v and 220vI am trying to make my FW able to be used with both 110V for here in the states and have a transfer switch for running of 220V in Australia via a step down transformer? Is this possible or not? Frank...Show More
time2rollNomadFeb 28, 2017I would convert power through the battery. Need a 100 amp charger, four batteries and 2000 to 3000 watt inverter to make 120vac you need.http://www.bestconverter.com/DLS-240-55-240-VAC x2 and get the parallel IQ controller.http://www.boatandrvaccessories.com/products/go-power-gp-sw3000-12-inverterThe 2000w should run your air but if you will need it a lot I would get the 3000.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
Related Content220v in 110v system110v vs 220v AC plugAccidentally plugged into 220v110V HookupVoltage protector 110V?
