CharlesinGA
May 03, 2020Explorer
M4Products. Not the cheapest, but probably the best.
I used These natural white Elite model But If I did it again I would use these Natural White Elite2 as they are even brighter, not the the ones I bought are not bright enough, butttt I like light.
I also like natural white, no color to it, not warm yellow, not cold blue but just pure white. I have been buying bulbs in Home Depot for the house and the kelvin numbers do not match the color at all. In those I ended up with cold white to get something that wasn't yellow or blue.
This is the third RV I have use M4Products LEDs in. I actually prefer the plate lights and when I do use them, I do away with the sockets and hardwire them in the fixture, but the present fixtures would need to have new flat metal plates made to replace the domed plates and I didn't feel like doing that (did just that on the motorhome, but was a lot of work) The plate lights put all the light in the right direction, down, with the lens dispersing a little to the sides, and the plate lights have the circuitry on a separate plate from the LEDS so they can better dissipate heat.
24 element plate light, good and bright
and 48 element plate light, super bright
By the way, the trailer I bought already had LEDs in it, but they were 1) warm white, and 2) el cheapos that already had LED elements burning out in them due to no heat sinks.
I saved a couple of them that still had all the elements working, and put them in the storage compartment fixtures since they don't get used very often.
Charles
Charles
