Byrogie
Nov 25, 2016Explorer
There may or may no be a disconnect switch. If there is it should be close to the battery, could be on the positive or negative.
There is for sure a DC breaker, should be near the batteries, follow the positive cable. Might be resettable, if not needs replacing.
Are you sure you hooked them up correctly? There are 2 30/40 amp fuses on your converter that will blow with reverse polarity.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
