wnjj
Feb 15, 2019Explorer II
acramer wrote:
wnjj -- Does it matter what type of extension cord I use as far as the wire inside? thickness? 10 12 14 gauge?
For just testing the receptacles out, no, since you won’t be loading it up heavily. Just don’t leave it that way. Plug in, test the receptacles with a test light or plug in lamp and then disconnect it. This is just a method to check all of the wiring downstream of the GFCI.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
